Hello,
I have an 2009 trooper t2 that has been sitting due to blown rear differential and i don't want to invest anymore money into it. So i have decided I will part it out everything is good except for the rear differential.
Let me know what you need or want and I'll get the pictures for you.
Sent from my SM-N900V using Tapatalk
Plumber. I rather not take the engine apart and end up with half engine sitting around so i want to keep engine complete and if someone want that I'll sell it or anything else. If someone want buy it complete then we can talk about price on that. I do not have a price set in mind for the whole thing yet. Tires isn't included unless at right price.
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By mark walkom
    • By tskm
      Tom
    • By Travis M
      Just purchased a T-Boss 760 and before putting any miles on it I'm going over all the fluids, grease and problem areas that I've read about online because I know the factory quality control is garbage.
      I've seen where everyone seems to have leaking axle seals after 2-300 miles on the T-Boss 550 and 760. I think I'm going to switch from the bellow-style diff breather to the automotive style diff breather that they use on my Tacoma and various other vehicles. I'll still keep it extended and infact run it even higher, probably into the air intake box, but I'm hoping this is what's causing the axle seal leak issue on these vehicles.
      I'll do the modification and report back every couple hundred miles and let you know. I currently only have 8 miles, so it will be a few months before I find out if mine leaks like everyone elses.
