Hey all,
Not new to forums but new to this one. Just picked up a Joyner T2 and looking to make a couple of upgrades. I finally was able to locate a half decent wiring diagram but if anyone has one I'd sure appreciate another one ( the one I downloaded is ok but zooming in blurs the font). I'd like to put a hard top on it. I'm not aware of anyone that makes one. I was just gonna attempt to cut out part of an old truck bed liner. I also need to replace the boots on it and I read somewhere that the boots for a '96 GEO Metro will work? Also, I have no idea what year it is. I've looked all over it and the only thing I've found is the sticker on the firewall behind the driver's seat. It states that this machine meets the 2008 CA emissions standards. Even the VIN plate doesn't have the year stamped on it. Any help would be great. Thanks.
  • 2 months later...
You can use the boots from a 97-2004 Subaru inner axle boot they are cheap and fit a little tighter I have two on my trooper for yrs now. Can't help you with the wiring. As far as a top goes I used a piece of 3/4 plywood sealed it and painted it cost 30$. Welcome and congrats
    • By Flanman55
      I have purchased a used Supermach700 (2008), It runs great after a new choke cable but. The temp sensor on the thermostat house is unhooked and can not find where it plugs back in. The fan has been un hooked from the sensor in the rad and cant figure out how it goes back together properly.  The fan was wired to a by pass switch and i just always leave it on but would like to work it properly. I assume the sensor went bad and not changed.
      any help would be great.
      thanks
    • By Gerald Dillman
    • By Marie
    • By Xov
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
