I'm hoping somone can help answer this for me. We have all seen the large lift kits on rzr wildcat rhino. We all know there is no lift for the trooper as of yet. I run 30" on mine why go bigger right? Here's the thing what makes our axles so different or why can't they be adapted to handle a lift like all the other side by sides. I know larger tires on our machines may require more power but that's not what I am thinking I'm just thinking more ground clearance and more wheel travel and it seems that the number one concern is the axles so what makes all the others different and why can't we??? I have spoken to two companies about a lift one possibly a portal box style and the other a possible bolt on 2-3" lift both companies were concerned about axle degrees. Any insight would help at this point it's a day dream
Nope need longer a arms on front and rear would need to be wider.. it's all about those cv's. Angle them too much and they blow apart..looked at it already..
Hey you find that front end noise?
Ya figured the wider stance in rear and front with the arms but with that being said if the axle shafts were longer wouldn't that help how do the axle cv work on all these other machines???? It's gotta be close to the same and I look at my brothers rzr 570 and the trooper shafts are defiantly thicker?? The noise is defiantly in the diff I narrowed that down checked everything in the front the one day I had to work on it I couldn't get the d/s cv off the diff then it started to poor rain and with end of summer and my kids hockey schedule I havnt got back into it yet sux ass lol
Prob end up needing slip joints too... lol
mo money.
I would use Toyota drive shaft with a Carden joint slip joint. Weld Carden to our bell at rear or at wheel utilize the slip joint and Bam.... Done.. longer shocks and your set..
There's never an easy idea I was just playing with thoughts in my head and I have been thinking all morning u think it's possible that noise could be a beating I did replace both bearing and all balljoints and I don't remember this noise when I started doesn't mean it's not poor timing. I'm gonna borrow a set of chassis ears tomorrow and put them on the front and see what happens. Man I miss wheeling havnt been in so long now
Why couldn't we have axles made with those joints u sent the link to lol. I guess the sky's the limit but u also have to accept what u have make it the best with in reason or move on
Charlie...what about lowering your diffs in the frame to cut down the angle ...the shaft still only has a certain amount of angle,but you should be able to lift it a couple of inches and still keep axles in thier safe zone..(so far Ive only relocated my rear diff ) primarily to allow for the additional travel with my fox air shocks...Hardy
I was playing around with ideas lol I guess that would be possible lowering the diff but my fab skills are not so great. I got to get the front diff open first and find why I have a knocking sound heard most when turning left
Hello Charlie
Charlie I need to get this done.I have the up grade and back lash done.You told me to get it done so i pulled it apart and set to specs.Please Get in touch with me or Matt.928 344 2117
Thank You
Matt
Did you get this figured out, could it be CV starting to bind up noise because you're turning to sharp to the left?
Hi Charlie
928 344 2117
[email protected]
Hi Charlie
Please give me a call.Need you to call 928 344 2117 Thanks Rich
  • 1 year later...
silverbullet10
We have been installing the new up grade for Trooper and Renegade.We have found some things to help to last much longer.Lenny had did most of the R&D we just found a few things like 12.9 allen head bolts.And we do this to all the rear differentials.Price of a stock unit with the upgrade.750.00 Takes about 10 days.
Rich
Register a new account
Sign in
    • By SouthernGypsy
    • By Nutcase
      I have a Joyner Trooper 1100 4 place that has been sitting for a number of years. I have everything taken care of but i can't get the fuel through the injectors. Fuel pump puts full pressure on them but they don't turn on or spray fuel. Any ideas?
    • By NC4wd
      Has anyone found a lift kit that fits an Axis 500? Mine is a 2021.
    • By JOSEPH LAMAR
      I have a 2020 axis 500 and I have replaced the TPS twice and the whole throttle body assembly once and still have code 122. I can barely drive the thing. It bucks and surges like crazy
    • eManualonline.com Save 30% OFF Sitewide, Use code: XMAS30
    • By Jacob E freeman
