Coolant light blinking
By Joe Breaux
By SteveS
By Adrian Domingues
Thanks for your help
By Joseph Sills
Has anyone modified the panel lights so they can be dimmed ? I haven't found a wiring schematic for the display .
By strike250
Matt
