2006 Mule 610 starts, idles, but no power
Go to solution Solved by John Taylor,
I have an underused '06 Mule 610 with 275 hours on it that has been sitting too much. It starts just fine and idles with no missing or stalling but, when I try to accelerate, even with no load on level ground, it stumbles and won't go unless I use the choke. I haven't tried to take it out for a run because I'm not sure it will come home under it's own power but it does seem to run OK with the choke fully closed. I changed the fuel filter and checked the air filter but nothing else yet.
  • 4 weeks later...
Sea Foam DID help but it did not completely solve the problem. The Mule would run after I cleaned the main jet but still had no power without the choke. I used the Sea Foam and it ran better but still needed the choke to run at low RPM's. I just got a call from the dealer I took it to and the carb had a part that needed replaced (in the float bowl?) and the 'pilot jet' needed cleaned. That service along with a belt replacement will cost $312.12. Thanks for the help. It did work but I had more problems than I knew.
    • By Mike Jenkins
    • By Grant
    • By rsar
