Fuel Pump & Instrument Panel Went Pffft
mahnoo51
We took our side x side out for a 20 mile ride the other night (which of course warmed it up pretty good). Next morning when we turned the key nothing happened. Specifically, no starter fuel pump sound and no instrument panel info. Everything else (headlights, turn signals, 4 wheel/2 wheel drive actuator) seems to still work and the engine turns over but won't start.
In checking the not real helpful manual, we THINK the problem may be a bad Electronic Control Unit. Is there a way to check that specifically or could it be anything else? Any advice would be greatly appreciated!
silverbullet
It is problem in the wiring connections.Pull fuse box off and see if any wires are brunt in the back of the fuse box.Swap relys and see if that works.I think Ernie has a wiring diag.Its vary rare the computer goes bad.Check members they should be able to help.JMC is moving but i think an eBay dealer will sell inventory on eBay.Not sure yet Casey didn't know.
Matt
