Parting Out 2007 Joyner Sand Viper 1100 Converted to VW Power
By Kingfish
By WCF
Hi Joyner Gang
By Qtband
I'm looking at picking up this UTV and this is what the owner says:
"All I know about it is it runs. Display does not work and it will not move! Front end or trans could be locked up. It moves some, but does not sound good."
My question is, what could the moving issue be, and how can I check it out when I look at it? I feel the price is right at $2000, but I'd like to know what I'm getting into.
By Bryan83c
Need input on compatible clutch sets I can upgrade joyner 1100cc 2018 sand viper with. Something autozone might carry and what cars are these chery motors most compatibility with
By Joe Breaux
Everybody out riding? Awfully quiet here recently. It's so damn hot here .We expect 112 to 116 heat index tomorrow..getting too old for that heat.
