    • By Bryan g
    • By Dennis
    • By downseast
      Hi everyone
      When I go to start it clicks as if there is a hydraulic lock and wont turn but after two or three attempts it then does turn over and start but I need to give it a bit of throttle to start – is this normal ?
      I haven’t changed the Lambda
      sensor yet, anyone know how much difference this might make ( I have a new Bosch universal to fit )
      I believe the T Boss was worked on by the previous owner
    • By GunnersTacklebox
