Hi Guys - we have a Joyner Python 800i which we use offroad here in Scotland.
The standard shock absorbers we can get in the UK are only lasting a few days and we are struggling to find uprated ones which will fit straight on - can anyone advise on good replacements or send me a link please ?
Alan
That is a sweet ride.
You gotta take them off and get a fully extended and compressed measurement. Then you should be able to match them up with a namebrand shock like fox, king, walker evan etc.
Joyner uses Chinese shocks with metric diameters. It would be best to get all new springs as well. With the correct valving and spring rates your machine will ride 1000 percent better. Here in the States I used Offroad Warehouse. They can help get you close to what you need. I drive a trooper so what I am using won't help.
If you are having trouble with the mounts not being the right size find a spacer and sleeve the bolt then drill your mounts to accommodate the size of the spacer.
Register a new account
Sign in
    • By bfisherman11
      In 2016 I bought a midsized Ranger ETX. I don't recall exactly my out the door price but it was probably less than 8k. I've used it as a work machine around our home and 38acres. It's always run great and requires little maintenance. Still running strong.
      So, for no reason I checked out a local dealer. I like the midsized UTVs so that's where I started. I was shocked the cheapest 570 I saw was a shade under 18k. I know an ETX Ranger was a budget SxS but wow, that's a 10k jump. When I was shopping back in '16 I think a 570 was about 1k more than my ETX.
      Well I guess I will be running this ETX till it breaks.
      Anyhow, I'm a big fan of the Rangers. When the time comes I'll be back but I had no idea. I haven't posted in a while. The ETX must not have sold a lot because you don't see many things posted. Hope other ETX owners had the same reliability I have had. I'm guessing if a cheap Ranger series like mine has been reliable then the guys with bigger ones are enjoying those as well.
      So, great machines, probably priced per the market but I had no idea. Ha
    • By allinone
    • By Ken rung
    • Get More For Your Device
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
