2009 Mule trans 4x4
By Dennis
By rdborra
By Will D
Hello, I have a mule 4010 trans that appeared to overheat based on the temperature light on the dash and it went into limp mode. No steam though. After letting it cool and the next day, I drove it around quite a bit and it did not have any problems. Any ideas on this. Do thermostats work intermittently? I would like to fix the problem, looking for advice. Many thanks
By John Doe
Hello,
I have a T-Boss 410. When I shift to H it starts beeping like it’s in R. It also shows R on the instrument panel. Fixes?
By bms stallion owner
hello, my BMS Stallion 600 is having accleration issues. the manual fails to show final gear oil diagrams very well... I have the owners manual and suspect issue is associated to transmission , I want to check the level of the gearoil. I located a drain plug (but not the fill plug nor dipstick). It will run - but wont exceede 2mph. Troubleshooting suggestions or comprehensive manual suggestions? Thanks
