2009 Mule trans 4x4
Glock_King
I bought a used 4010 and have had it a couple months now with no issues or problems. Recently I have used it to pull a stalled vehicle about 30 feet and pull out a stuck vehicle. Both times I put it in 4wd and locked differentials. After each occasion while driving the unit it feels as though the park brake is engaged and is very sluggish and loss of power. I have double checked the diff and 4wd as well as engage and disengage the brake in case it was dragging or slightly engaged, everything seems dime there. Any ideas why it would do this or what is causing it ? Any help would be greatly appreciated
  • 2 months later...
    • By mac66
    • By Mike Turner
      American SportWorks LM 650 won’t start at times. Starter won’t engage the solenoid just “clicks” much like a weak battery would cause. Battery was replaced and problem went away and then came back. Replaced positive battery terminal. Problem resolved then returned. Replaced negative battery terminal. Problem gone then returned. Replaced the positive and negative battery cable ends. Problem resolved and now returned. The repair lasts for maybe 12 starts, then the solenoid just “clicks” again as it will with a weak battery. So I replaced the ignition switch. Problem solved for a week. With each “fix” the problem is resolved but only temporarily. Does anyone have any suggestions ? To replace the starter is expensive especially if it’s not the problem.
    • By sxr951
    • By Off Grid Refugee
      I have a yanmar longhorn 6 seater which I believe is having fuel delivery issues.  It will run off of starter fluid and will sometimes run on gas but will not idle.  Fuel pump is new and verified to put out 56 psi.  Injector is new, I'm reading 10.5 volts at the injector, gas is new.  The unit will run when the engine symbol is not present at the gauges.  Diagnostic port doesn't appear to be present, can't find it where yanmar says it should be.  Oil is full but old.  Any ideas what's going on here?  Is there a maintenance function that will shut this machine down if it has old oil?
    • By Jim D
      MSU 500 does nothing when you turn the key. No power to display, fuel pump or anything. Come back a while later and everything works perfect. Starts right up. Battery is fully charged. Could this be the ignition going bad. When it doesn't power up I've found nothinf that will correct it other then waiting and trying later.
