My mule is hard to get into hi gear, low gear and reverse are fine. Is this a linkage adjustment issue? You have to slap it into high gear several times before it stops grinding and goes into gear. If it is a linkage adjustment issue, is there an order you have to adjust the linkage?
    • By Mike Jenkins
    • By Pick a name
    • By Paul L
    • By rsar
    • By TjB
