I am having a really weird issue with my mule. So it is at my deer lease and stays down there year round and gets used only on the weekends. The issue I have is when I get there on Friday I start it and run it Friday evening and Saturday with 0 issues. Sunday it starts slow and runs fine initially then in a matter of minutes it starts crawling even when floored I think it is a fuel issue of some sort but the thing I can't understand is why does it run fine for a day and a half then all of a sudden it runs like crap dragging and not wanting to go anywhere. Then park it and let it sit until the next Friday then it is fine again. Anyone got any ideas.
  • 2 months later...
  • 1 year later...
    • By rev6engines
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Kingfish
    • By felo72
