Electrical issue
By SayHiToRambo
08 trooper 1100
thanks!
By Buck
My father-in-laws 750 hisun will not change gears unless he completely turns the motor off then shifts. I thought it might be a brake problem but he thought clutch. He took it to a jackleg down the road and he basically charged him $300 and did not fix a thing. Any ideas would be useful because he really can’t afford throwing money at it.
By Ken rung
By CYJSP2009
Dear Joyner owners
3. Cables,
4. Brake parts
5. Engine parts
6. Other parts.
Have a good weekend
Casey / Leaf Asia
2023-11-17
By rocmoc
This is rocmoc/Michael one of the first on this forum when the Joyner was one of the most active topics. First an update of others. The earlier members will also remember Lenny and Jeff. With myself we organized the first Jamborees in 2009-2012. Sadly if you have not heard we lost both Lenny and Jeff in 2018. A great loss to the community. Myself: Still around but rolled over to Jeep and Arctic Cat Wildcat. The Wildcat design still remains me of my old 2008 Trooper. Doing well as the Last Man Standing but cleaning out the garage. Found some New and used Trooper parts I will list in the parts section. Wanted to give you all a chance before I list on Ebay. As many of you knew Lenny listed a lot of stuff on Ebay. Will I partnered a lot of the stuff with him and I still have stuff. Take care and I will check in for message should you want to ride. Still make it to Utah every other year and am still in Southern AZ.
rocmoc in AZ/Mexico
Register a new accountSign in
