I have a 2009 Joyner Trooper II with a small problem.
The plastic blocks that plug into the relays behind the passengers seat for the Cooling fan ,Fuel pump and ECM were failing so I had to cut each of the 4 wires that terminate in the blocks and install female spade connectors to fix the problem. In doing this I believe I got a few wires crossed and I was hoping someone out there with a 2008 or 2009 Trooper II could take a picture of their three relays defining wich wires (color coded) go where on each of the 3 relays and forward that to my e-mail, [email protected]. I would greatly appreciate this.
KINARFI,
Thank you for replying to my post. It appears you have been around the Joyner based on your Album pics etc, great support for me hopefully. I see you have converted to FET's and I am more so a novice to amateur regarding the electrical, so please bear with me. I looked at your picture and do see wires that are common, but I was hoping I could either get pics of the relays for the ECM, Fuel Pump and Cooling Fan as they plug into those relays, allowing me to identify the correct wire based on color for each relay. I uploaded a few pics of my relays prior to removal and those are in the Photos tab under albums I believe, Joyner Trooper II relays.
Maybe we could talk or whatever you feel is best, but I would greatly appreciate the help if your willing and have the time. My Number is (928) 533-7010 and its Mark.
Kinarfi,
Thanks for responding and I did insert a few photos in the photo uploads tab under 2009 Joyner Electrical if you could take a look.
Thanks again,
Mark
Sorry, I don't recognize any thing in the photos, what's happening or not happening?
You can find those under, the Photos tab, then Albums and then 2009 Joyner Trooper II relays
Saw the photos, I just don't know what you're showing, so what's happening or not happening?
Jeff
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By staind
      thanks Dan D. aka staind
