K&N Filters has designed a replacement air filter for the Polaris Ranger. See the complete list of vehicles below. The round K&N air filter is custom designed to fit into a stock machine with no cutting or fitting required.
The PL-5008 offers your Polaris the air it needs for optimum horsepower. It also works great in [...]
View the full article
    • By Paul L
    • By SSgt1994
      Myron
    • By SpaceGhost
      They will be coming off.
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
