Yoshios Custom Joyner SV1100
By Kingfish
By Woody77
By Chas
When traveling in the 40 mph range and throttle is released machine starts surging instead of a gradual slow down any help would be appreciated as dealer is clueless
By Alien10
I added lights to the Coleman Outfitter 550 last fall. I bought lights on line from Nilight, a 300 W 12" light bar mounted forward and 2 square 4" floods for the rear. Those are mounted on the roof corners facing rear and downward just beyond the tailgate. Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights. Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch. Rear work lamps were wired in using a rocker switch installed in the dash. Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
What have you used if anything for auxiliary lighting on your UTV?
