I recently purchased a 2015 Polaris Ranger Crew 900 with a spacer lift and 27" tire upgrade. My issue is the MSA M20 wheels that I purchased for the 27" tires are causing me some issues when it comes to taking the wheels off. The clearance around the lugs is very small and the standard ATV star style lug wrench won't fit. Can someone tell me what size lug wrench is required? Will I need any special extensions to compensate for the minimal clearance issue?
Any and all assistance is appreciated.
Sent from my iPhone using Tapatalk
    • By Dennis
    • By Gary Odom
    • By Flanman55
    • By John Doe
      Hello,
