  • 4 weeks later...
Can anyone message me a pic of the 2 plugs that come out of the computer on the trooper I have 2 wires that's been pulled out and it won't get and fire to the coil and fuel pump won't run. There are 2 grey wires loose at the plug
Sent from my SM-G900V using Tapatalk
    • By Kingfish
    • By hetovi
      Hello everyone.
    • By Paul Angstadt
      Paul
    • By diamondjfarm
      Thanks.
