Hrs. on a UTV
By davebuckholts
I just picked this UTV up off of Marketplace. It needs batteries.
I am installing a single 48v lithium battery.
The on board charger, a NOCO Genius GX 4820, has a lithium mode.
Has anyone here used this charger on new lithium batteries? I want to be certain of the compatibility before hooking the charger to this expensive battery. **
I got in touch with NOCO and they told me the charger is fine to use on a new LiFePo battery.
Nice charger. Many modes. New ones are running about $550.
By rsar
By TjB
By Will D
Hello, I have a mule 4010 trans that appeared to overheat based on the temperature light on the dash and it went into limp mode. No steam though. After letting it cool and the next day, I drove it around quite a bit and it did not have any problems. Any ideas on this. Do thermostats work intermittently? I would like to fix the problem, looking for advice. Many thanks
