The PRO 2500 is an air/hydraulic 48" Hi Rise Heavy Duty Lift Table. Once the vehicle is loaded and raised to working height, side extension panels can be arranged in a configuration of 2, 3, or 4 to accommodate different vehicles. 4 piece panel (quartered) side extension kit (15 1/4" W x 46" L) with 2 ramps 40" L x 15 1/4" W, and is ideal for Motorcycles, ATVs, UTVs, Trikes, Spyders, Golf Course Equipment, and other commercial use.
The lift table with side extensions measure 60"W x 93"L, and the ramps measure 40"L x 60" W.
CALL CLARK HEINTZ TOOLS & EQUIPMENT LLC AT 603-234-2612 OR VISIT:
http://www.nhproequip.com/pro-2500-48-high-rise-air-utv-motorcycle-lift-free-shipping
PRO 2500 48" High Rise Air/Hydraulic Lift Includes:
5 YEAR WARRANTY ON STRUCTURE
2 YEAR WARRANTY ON HYDRAULICS
FREE SHIPPING
* 1. Free Shipping to Commercial Location with means to offload.
* 2. Home Deliveries: We still pay the shipping, but customer is responsible for home delivery charges.
Air/Hydraulic control unit
2,500 lb Capacity Lift with Maximum Lift Height: 48"
4 Piece Side Extension Kit, expanding the lift table to 60" wide
40" Detachable Drive-On Loading Ramp Set (3) features low angle to protect vehicles and stays positioned on the ground when lift is raised, easily moved aside
Adhesive Back Grip Strips for Loading Ramps
Drop Panel for Rear Tire Change
Rubber Lined Wheel Vise
Super Heavy-Duty Hydraulic Cylinder Assembly
High Quality and Dependable Locking Mechanism
Extra Wide Roller Bearings in Scissor Mechanism
Smooth Finish Table Top for Easy Cleanup
Work Table has multiple welded cross members underneath to support the heaviest of vehicles
Equally Spaced Holes on Table Edges to Accept Tie Downs
9 Position Safety Locking System secures lift in place while working, max height 48"
Grease zerks on X frame maintains smooth operation
Powder Coated Finish for durability
PRO 2500 48" High Rise Air/Hydraulic Lift Specifications:
Weight Capacity: 2500 lbs.
Method of Lift: Air / Hydraulic
Power Unit: Air Control unit
Full Raised Height: 48"
Low Height: 7.87"
Table Length With 40" Loading Ramp: 133"
Table Width without Sides: 29.5"
Table Width with Sides: 60"
Loading Ramps: Main ramp 40"L x 29 1/2"W (1), side ramps 40" L x 15 1/4" W (2)
9 Locking Positions: 22 3/7", 27 1/6", 31", 34 1/4, 37", 39 1/2", 41 3/4", 43 3/4", 45 2/3"
Lift, Air Control, Wheel Vise, and X Wide Side Extensions Weight: 967 lbs. (4 separate packages)
    • By Grant
    • By A P
    • By clint501
    • By Joseph Sills
      Has anyone modified the panel lights so they can be dimmed ? I haven't found a wiring schematic for the display .
