Got a brand new 4010 Trans Mule in 2015. Kills the battery after 3 days of no use. What the hell ?
Previously I had a 3010 from 2007 and this never happened as it could go weeks without draining the battery. What is it with this 2015 model ??? Is it something to do with the new fuel injection and computer ?
I'm just about fed up.
Parasitic draw on the battery, is more common these days. It's standard on vehicles that have an onboard computer. But when it goes to this extreme, obviously something is wrong. On cars, the problem sometimes can be found by pulling a fuse out, and test for an amperage draw. Then just repeat the process until the offender is found.
Shouldn't the warrant cover this?
    • By Gorj
    • By rsar
    • By rdborra
