Offroad Expo - Pomona
By Ron from the Mitten
I purchased a 2008 Qlink Rodeo 700 a few years ago. I am from Michigan. Anyone know of any local repair shops? I had a dead battery, so I replaced that, started right up, ran the quad down the road, (this was last year), put it in the barn, shut it off. then a couple weeks later, went to go start it again, and nothing. I have power to the dash lights, horn, turn signals, wench etc, but nothing to the starter switch, and I hate electrical crap. Battery still reads 12.x volts.
Any suggestions would be amazing. I've owned it over 2 years, and haven't run 1 tank of gas through it. No time to screw with it, and very frustrated. Hoping someone can offer some advice of value.
By alevins
Good day all,
searching here but cannot find the answer, Hisun been working fine and now reverse limiter seems to be engaging and cannot back up, cannot find a clear solution to disable the limiter. found a possible relay? not sure which one or to cuut a wire at ecu but a picture or diagram would be helpful
thank you for any help in advance
By MJG
Hello,
I found an 08 Renegade for sale and looking to purchase it. I haven’t heard too much about these machines and any insight would be much appreciated. Are they good machines?
By Amagi
Hi to all. I’m new on this forum and I need some help. I have a 2008 arctic cat 700 xtx prowler. I have no spark.
I have done the following repairs.
changed piston and cylinder
change CDI
change ignition coil and spark plug
changed speed sensor
changed stator and flywheel
Changed voltage regulator
after all this I still have no spark.
i have verified all fuses and they are all good.
please help. I would like to get it running.
By MISTERTIRE66
Recently inherited 08 joyner renegade r4 800.. seems to be sound mechanically but I cannot find bal joints. Any pone help with other replacement part number please.
