Renli owners... We are trying to develop an adjustable fuel controller for the renli rl1100. We would need to borrow an ECU to do the programming. We would cover all of the costs for the shipping and the R&D. Then you would get your ecu returned along with a new fuel controller for free. If you are interested in the please contact us at
SilverBullet Motorsports
928-344-2117
[email protected]
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Kingfish
    • By Ridge Runner
      thanks
      Ridgerunner
    • By Browner010
