Has anyone found a fuel injector that will work on a stock motor? Something I can pick up at Autozone etc... I have one that will not cooperate! I've tried cleaning it with seafoam and I can see it pulsing manually and on the motor. But when I put it back together it does nothing at idle. I can disconnect the cable to it and no change in idle (which is rough) If I move the injector to another cylinder the problem follows it. So... I need a new one to try.
I searched the Chery engine until I found a car model. Then searched the car model on a Chinese autoparts store and found them for $16/ea lol! I haven't tried them yet... I was going to ask someone travelling to China to grab some for me. The company I work for has offices in China so we get people over there every now and then.
Register a new account
Sign in
    • By BMurph
    • By BMurph
    • By Buddee
      2010 Hisun 500 - Carbed'.  She sat for about 3 weeks since last use.  Couldn't get it started.... has spark but plug was not wet.  Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working.  Still nothing.  Put gas in the plug hole.... started right up and idled as normal and drove perfect.  Used it for the rest of the day without issue.  Tried to start again next morning.... same problem.  Poured gas in plug hole again.... started up and best kind again.
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • Get More For Your Device
    • By vachi
      hi everyone i have this 2021 Hisun forge 250 that won't start. no spark no fuel.   when i turn the key on i dont hear the relays click or fuel pump come on. it does have power but the relay doesnt ground the pump or the ignition coil. dont know if there are any safety switches on this model or not.  it does crank and all the accessories work. i  hot wired the pump and it does work.  i found a wiring diagram but it's very hard to figure out and was hoping someone has seen this before. all fuses are good. thanks in advance.
