Confused on relay wireing
By Robbie Wyre
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By Buck
My father-in-laws 750 hisun will not change gears unless he completely turns the motor off then shifts. I thought it might be a brake problem but he thought clutch. He took it to a jackleg down the road and he basically charged him $300 and did not fix a thing. Any ideas would be useful because he really can’t afford throwing money at it.
By BMurph
