I finally had time to dig deeper into the Trooper T4 not having spark when cranking.
I have taken the rear fuse/relay block loose and inspected the connections. All fuses are good.
I don't know if the correct size fuses are in all the slots. Some look like they are bigger than the
manual calls for. All have battery voltage when the key is on except the 4th one down. The manual
shows that it is for EFI.
When should the EFI fuse have battery voltage and where does it get it from? ECM or Ign switch?post-3653-0-13341000-1464230126_thumb.jpg
    • By Paul L
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
    • By D MAYNARD
                                    Thank You,
                                  D Maynard
    • By Tejun
    • By camojay
      1400 miles on it
      20240817_133539_1.mp4
