1100 Sand Viper/Renli 1100/ Orieon Epic/ Durrux DRX4 Intake Manifold Set
By lmarkie
Any thoughts?
By mac66
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
By sxr951
