www.recreationalwatts.com FM/AM - Bluetooth - USB/AUX Input Jack, SiriusXM Ready
Please don't make the mistake and spend $599.99 for the Polaris Dash Mounted Audio System that you will not be able to hear while driving your Ranger Our system uses the same Polaris factory mounts for a clean professional look, is more durable, and produces twice the sound volume and quality, guaranteed!
Our higher wattage radio head unit will come mounted in the factory dash mount plate using an aluminum bracket instead of plastic mounting tabs that are known to break.
Our high output 6 1/2" Kicker KM LED Series 2-way speakers will come mounted in the factory kick panels ready for easy installation.
All our audio kits are extremely easy installation. Plug and Play.
    • By Marie
    • By BMurph
    • By JOSEPH LAMAR
      I have a 2020 axis 500 and I have replaced the TPS twice and the whole throttle body assembly once and still have code 122. I can barely drive the thing. It bucks and surges like crazy
    • By joynersfuntillitbreaks
      so i just picked up a 2008 1100 trooper and iv ordered a few parts for it now and 99% of what i got fits perfect my issue now is my rear wheel hub is stripped out got a new cv and it fits great but i order 2 different hubs from 2 different places now and they are both wrong the spline opening is to small to fit the factory cv shaft and yes the shaft factory part #s are the same paid 250 for an original new replacement if anyone has anything that works to replace the original hub please point me in the right direction
