The old axle came out without much trouble. I installed the new one. After driving it around some I noticed some rear end grease leaking from the diff. There is a gap between the inner cv and the diff now that I didn't notice before. I can't get the axle to go in any farther or I can't get it to come back out. Any ideas or suggestions?
    • By rdborra
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By Tejun
