FM/AM - Bluetooth - USB/AUX Input Jack - Pandora Ready www.recreationalwatts.com --------------------------------------------------------------------------------------- This is a thing of beauty. Polaris Ranger Dash Mount fitted with the Rockford Fosgate PMX-2. Notice how the head unit is angled towards the driver for easier viewing. Pretty cool -------------------------------------------------------------------------------
All our audio kits are very easy to install.
Plug and Play.
INFORMATION/DETAILS
  • Rocford Fosgate PMX-2 Head Unit - 2.7" Color Display - Marine Grade - FM/AM - Bluetooth - AUX/USB Inputs with USB Charging - Low Voltage Warning Alert - Pre-Amp Outputs - Independent Subwoofer Level Control - 7 Band Graphic Equalizer - Pandora Internet Radio Ready - 50 Watts x 4 @ 2 Ohms
  • Kicker KM Series 6.5 Inch 2-Way Speakers - Marine Grade - 65 Watts RMS @ 2 Ohms - 35-21,000 Hz
  • FM/AM Antenna
  • AUX/USB Audio Input Jack (This input jack will already be installed in the dash mount plate)
  • OEM Radio Dash Mount Panel (Head unit will come installed in this panel)
  • OEM Kick Panel Speaker Mounts (Speakers will come installed in the speaker mounts)
  • Mounting Hardware
  • Wiring
  • Owners Manual
  • Instruction Manual
  • 2 Year Warranty
Fits:
  • 2013 - 2016 Polaris Ranger XP 900 and XP 900 Crew
  • 2015 - 2016 Polaris Ranger Diesel and Diesel Crew
  • 2015 - 2016 Polaris Ranger 570 Full Size
  • 2015 Polaris Ranger 570 Full Size Crew
  • 2013 - 2016 Polaris Brutus, Brutus HD, Brutus HD PTO
NOTE: This kit will not fit the "2016 Value Series" full size 570 Ranger
    • By Rick A
    • By Troy C
    • By Brett
      A while back I was looking at an auction UTV plow and the mounting of it.  Looked like it had an "H" bar with two pins that hooked into brackets on the front frame of the UTV.   I have a bunch of 1/4" x2" angle iron, and some 2"x1/2" flat stock in the barn.   I was thinking of welding up a bolt on implement mount that would provide 2 holes about 14" apart, that pins could be used to hook up an "H" frame for a plow or even a straight bar across with pins to hold it in place.   The angle iron "A" would utilize the existing bumper mounting bolts front and bottom, and have the two channels "B" with holes for individual pins or one large bar across. Those channels would be welded to the ends of the angle iron.
      Anyone ever try this for a front mount?   It would be close to  this one that is for sale on the net.  It is supposed to fit a KFI plow mount.
