  • 10 months later...
    • By SayHiToRambo
      08 trooper 1100
      thanks!
      Greetings everyone! I'm a new member here and looking for aftermarket mods available for my UTV. I've got a Kioti K9 2400 cab. It's a 24hp diesel. The cab model has factory heat and A/C. It's very similar to the Kubota. Any suggestions for aftermarket parts would be appreciated.
      Cheers
    • By rsar
    • By SouthernGypsy
    • By se3388
      Steve.............
