Polaris XP 1000 Turbo front and rear stock suspension, good condition, no ball joints in a-arms, take offs, installed LT kit, will separate front and rear but will not sell just part of front or rear
    • By JSwearer
    • By KimAC
      -Kim
    • By NC4wd
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
