Considering purchase of Massimo gator or militia 1000. Only considering Massimo because the title says "buggy" and I can get a tag on it here in the VI. I have seen some bad reviews though. Any thoughts on Massimo? Or any other recommendations that have buggy title?
  • 5 months later...
  • 4 months later...
  • 2 months later...
    • By tskm
      Tom
    • By Kingfish
    • By felo72
