silverbullet
Hello 4,000 Rpm if you are going to drive a long time at this speed.Keep your eye on the temp.gauge if the temperatures goes up slow down a little.Make sure you a snorkel the air filter to the roof. Use pvc pipe.
Thanks you sir. I had noticed if I drove very far and above 4K the temp would start to rise but figured the RPM range was above that. Thanks for the info. Sounds like I need to slow down a little
    • By Mike Jenkins
    • By Duane Baker
    • By aefron88
    • By Grant
