silverbullet
Hello 4,000 Rpm if you are going to drive a long time at this speed.Keep your eye on the temp.gauge if the temperatures goes up slow down a little.Make sure you a snorkel the air filter to the roof. Use pvc pipe.
Thanks you sir. I had noticed if I drove very far and above 4K the temp would start to rise but figured the RPM range was above that. Thanks for the info. Sounds like I need to slow down a little
    • By rev6engines
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By Jacob E freeman
    • By Will Sutton
    • By Reynolds Rocket
    • By lmarkie
      Any thoughts?
