my 2009 mule 610 4x4 keeps blowing the main fuse. the dealer said a controller needed replacing and it was not cheap. it cranks up and after
about a minute the oil light will come on and then the fuse blows.
kind of a novice when it comes to diagnosing electrical problems.
has anyone had this same or similar problem. Or, do you know anyone that has.
any help will be appreciated.
I took it to shop and the voltage regulator was over charging causing the 30 amp fuse to blow. also burnt out the controller. had to replace the controller and regulator. problem solved.
  • 4 years later...
  • 3 months later...
HELP!  My 2009 Kawasaki 610 Mule blows the 30 amp fuse, with all switches off.  Replacement fuse blows immediately.  Unhook regulator, no fuse problem.  Plug in regulator, fuse blows.
