American Race Car Driver Robby Gordon Greeted Enthusiastically at Dakar Rally Preliminaries
Stage No. 1 Set for Sunday Morning in Buenos AiresBUENOS AIRES, Argentina (Jan. 3, 2015) â A massive announced crowd of 800,000 enthusiastic fans hoping to catch a glimpse of their favorite drivers and riders stood outside Saturdayâs mandatory race briefing and opening ceremony for the 37th Dakar Rally. Many of the drivers and riders [...]
No related posts.
View the full article
      Any options on this machine
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
      From the fella selling this UTV, he claims its to set the idle on fuel injection because the engine will not stay idle or when it starts sometimes it idles too high.
      My Question if anyone had any issues with their Massimo 550 and if it was actually the TPS or something else that would allow the machine to idle correctly.
    • By Qtband
      I'm looking at picking up this UTV and this is what the owner says:
      "All I know about it is it runs. Display does not work and it will not move! Front end or trans could be locked up. It moves some, but does not sound good."
      My question is, what could the moving issue be, and how can I check it out when I look at it? I feel the price is right at $2000, but I'd like to know what I'm getting into.
    • By FGT
