    • By Bassarino51
      My 2014 Odes with less than 1000 miles suddenly won’t turn over with a fully charged battery.
    • By mehe
    • By Kinarfi
      Dealers - - - also see http://www.utvboard....dpost__p__16044 & http://www.utvboard....dpost__p__16045
      No Limits Powersports in Arlington Texas - Contact Jarrad (Snowman6479). (817)695-1151 http://www.joyner-atv-utv.com/
      Silver Bullet Motorsports in Yuma Arizona - Contact (silverbullet). (928) 344-2117 http://www.silverbul...otorsports.net/
      Thin Air Powersports in Spring Creek Nevada - Contacts Tim (Anylizer) or Amanda (Long Track Lady) (775)753-8223 http://www.thinairpowersports.com/
      McCoy Motorsports in Pikeville Kentucky - Contact Art (Art) (606)432-1556 http://www.tobefast....sa-c-63727.html
      Mudslingers Motorsports, Alberta, Canada, Trevor Carson (780) 576-2860 cell: (780) 984-2711 http://www.mudslinge...website_006.htm
      Joyner USA In Phoenix Arizona - Contact Brandon Deruiter Office (480) 882-9612  Email [email protected]   Web site Joyner-usa.com
      I also take suggestions for any and everyone!!
      parts & pieces from dealer in Germany
      http://www.utvboard.com/topic/3168-joyner-parts-and-all-chery-and-lj276-engine-parts/?p=18349
      AIR FILTER K&N RU-1000, RC-4160, and another link
      If you have the new 09 filter box, w/ Fram # CA-7764
      ALTERNATOR BELT 14mmx 755mm replacement that works....Carquest #K040292
      Alternator Belt - Checkers Auto Parts KO40292 - Exact Match
      Battery, according to 2 scoops, Duralast 51-DL is the correct size.
      OIL FILTERS
      Troopers with Thread Size 20X1.5 MM can use:
      WIX 51347, 51334 --- Napa 1347, 1334, PS1334 --- Fram PH6010A, PH3593A
      Troopers with Thread Size 3/4X16 " can use:
      Fram PH4967, Napa 1394 & Wix 5194 (slightly longer than original, Wix 51396 (even longer yet).
      OIL COOLER See thread, http://www.utvboard....768-oil-cooler/
      Oil Pressure Gauge Replacement
      Zorro found some at his Local Marine Supply store
      Sending Unit -- TeleFlex Morse Part # IA15001 0-80 psi, 240-33 ohm
      Gauge -- TeleFlex Morse Part # 57903P 0-80 psi, 240-33 ohm
      Manufactured by Veethree Elec. & Marine LLC
      together cost aprox $80.00
      Says it fits the existing hole perfectly Thanks Zorro
      Plumber added this reference; http://www.spydertal...pressure-gauge/ which Crosses over to a Sierra part# 01858990
      IMHO--I would move the the sender away from the exhaust manifold.
      FUEL FILTER replacement, Fram Fuel Filter G4777
      FUEL PUMP replacement, Bosch 0 580 254 910 According to Brostar, (Thank You!!)
      http://www.ebay.com/itm/Hayg-OEM-Inline-Fuel-Pump-0-580-254-910-0580254910-New-/230568738342#vi-content (updated 05-2015)
      PRE FILTER KNN-RC-4160-DK prefilter
      HEAD LIGHT REPLACEMENT Sylvania H5006 replaces the whole bulb, It works sooooo much better than the original.
      SPARK PLUGS NGK Iridium BKR5EIX-11, NGK 2387, NGK BKR7ES-11, Bosh 3311, Denso Iridium plug 5310 IK22
      CV Boot Kit There appears to be a difference between inner and outer boots, I used a NAPA CVB6862340 for my outer rear, fit good but not tightly on the CV end, I held it on with Tyraps
      Autozone part # 03606. Comes with bands and grease for $11.99, quick/split boot. K2181 95 Geo Metro $15.99
      NAPA #686-2149 fits for the Troopers inner CV. It's a speck tight but only about 1/16".(Lenny)
      Napa 686-2181 CV Boot from a 95 Geo Metro.
      http://www.norrecind...tart=1&cat=1394 or
      Norrec Industries then Application, then UTV, then look up joyner, they have them all
      Polaris CV Boot Kit # 2203438, (PR-8061)
      Also see CV boot for driveline? - UTV BOARD - Side X Side and UTV Forum
      Valves shims are 25mm, Joyner shims start at 2.18 and increase in increments of .02 up to 2.80, The Honda shims come out of CB450s and GL1100s, start at 2.30 and increase in increments of .05
      http://www.mawonline...gle/P137630.HTM
      http://stores.ebay.c...&_sid=120606839
      Master Electrical Switch Key
      http://www.jegs.com/...oductId=1231908
      http://www.pegasusau....asp?RecID=1467
      Make your own, it's easy, I did, just in case mine breaks.
      At the suggestion of one of our members, here's some info on the gas gauge sending unit.
      3 ohms is full, 13 ohms is 3/4, 23 ohms is 1/2, 63 ohm is 1/2, 110 ohms is empty.
      Electrical readings are: F=0.75v-98ma, 3/4=1.91v-82ma, 1/2=2.7v-71ma, 1/4=3.3v-62ma, 0=4.1v-52ma, E=5.0v-39ma
      0 is top of red zone, E is bottom of red zone.
      Manuals and Information
      Trooper T2 weights, 380lb. on each front wheel, 480 lb. on left rear, 520 on right rear TOTAL = 1760 pounds
      down load this and save it!!!!
      Torque Values Select Your type of bolt at the top. http://www.engineers...bles/torque.htm
      My Snorkel Made from a Sears ShopVac 7' Hose and the Extension Wand,
      Oil Drain QuickOilDrainValve.com
      http://www.oildrainvalve.net/ez-oil-drain-valve-ez-103-12mm-1-25/
      the best way to change oil, IMHO Kinarfi
      Fram Sure Drain #SD3
      Paint as recommended by Brostar: http://www.zynolyte..../rustmaster.asp
      Supplier of parts in General
      http://www.cxracing.com/default.aspx
      http://www.summitracing.com/
      Pegasus Auto Racing Supplies - Home Page
      TireRack.com
      McMaster-Carr
      Discount Hydraulic Hose.com
      Tie Rod Dust Boot, Checker Auto#13566
      Rod End / Heim Joint Seals , http://pitstopusa.co...-end-seals.html, thanks rocmoc
      Ball Joint Rod Ends AKA Heim Joints
      16 x2.0mm threat, 16mm ID, 21 mm thick,
      I got mine at McMaster-Carr 4483T36
      PTFE/Kevlar Insert, M16 x 2.0 x 40.mm shank, 21,966 lb static radial load capacity, 23°, $25.60 ea. or $204.80 for 8
      http://www.vxb.com/page/bearings/PROD/Kit12360
      http://www.vxb.com/page/bearings/PROD/Kit12960
      14 Inch Tires That fit our Stock Wheels Note that the stock lug bolt pattern is 4 X 115
      STEEL WHEELS http://www.utvboard....dpost__p__10804
      JC Whitney for all Auto parts - Car, Truck, Jeep, Motorcycle & RV Parts
      Interco Tires SSR-24R - INTERCO SSR Series Tire - Quadratec
      Interco Tires SAM-12 - INTERCO Super Swamper TSL Tire - Quadratec
      TSL Radial | Interco Tire
      Maxxis Bighorn 2.0 AT26 X 11R 14
      General Grabber AT2 27x8.50 R14 95Q 6PR OWL $90.10 http://ssl.delti.com.../GRABBERAT2.jpg
      National Chaparral A/P 27x8.50 R14 95Q 6PR OWL $113.80 http://ssl.delti.com...ChaparralAP.jpg
      Kumho Road Venture MT-834 27x8.50 R14 95Q 6PR OWL $110.30
      Mastercraft COURSER A/T 27x8.50 R14 95Q 6PR OWL $87.00 http://ssl.delti.com...t/COURSERAT.jpg
      Cooper Discoverer LT 27x8.50 R14 95Q 6PR OWL $99.60 http://ssl.delti.com...iscovererlt.jpg
      Laramie Performer RV 27x8.50 R14 95Q 6PR OWL $100.70 http://ssl.delti.com...PerformerRV.jpg
      ITP MUD LITE XTR 27-9-14 $87.99
      ITP TERRACROSS R/T 26-9-14 $144.99
      15 inch Wheels [Be sure to get the correct lug nuts, 12X1.5
      Vision Wheel Inc Vision Wheel
      ITP has one now also, getting info. ITP TIRES - The World's #1 ATV Aftermarket Tire & Wheel Source :: Holeshot
      Non Trooper Info
      u joints for joyner renegade are Spicer 5-1501X and Precision 391. They are American work great. graybeard9
      Differential Bolts
      40 28 to Full 25 96144A227• 8.33
      1100 Trooper T2 ECU Wiring Diagram.pdf
      Joyner Trooper Differential Rebuild Kit .doc
    • By GrandpaVader1138
      Joyner appears to no longer have a web site up.  They can be reached at this number for parts:  480-882-9612
      https://www.buzzfile.com/business/Joyner-USA-Inc.-480-882-9612
