Seem to have got the alternator on my trooper full of mud and it destroyed itself.
Here is my question, is the alternator from a 2012 JD gator 825i the same ?
I know they used the Chery SQR372 engine and everything i can find says that this engine from chery used the same alt. and on ebay the pictures of the alternator look the same but noone can tell me if they are in fact the same. The JD dealer doesnt have one on the shelf to compare.
The reason I'm asking is that i can find a new Alt that fits the Gator for <$200 shipped to me and te only alt i can find to fit the trooper is $230.
just how badly destroyed is it, hose it down real good and replace the bearings, then if it doesn't work, you can add a new voltage controller/regulator, I've rebuilt a couple of them for forum members in the past.
Jeff
    • By Nutcase
    • By Reynolds Rocket
    • By lmarkie
      Any thoughts?
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
    • By fishhouse3
      This machine is ready to go and needs nothing - just hop in and hit the trails!  I have over $20k invested in this machine. Priced VERY fair to sell quick at less than half that!!!
