Use your Smartphone to control and monitor almost every function on your UTV/ATV vehicle wirelessly. You can turn on the engine, seat or hand warmers from the comfort of your home. Or if you were in a camp in the woods at night and you wanted to scare off unwelcome animals, turn the engine on, sound the horn and switch lights on and off from the comfort of your tent or cabin.
Website:- http://www.optistartremote.com
    • By boydog40
      thanks guys
    • By Reynolds Rocket
      I have a 2017 Intimidator XD4 800cc 4x4.  It will run great and then it's like it goes into safe mode and only runs on 1 cylinder.  It's not fouling out the plug when it happens.  Some times when I stop and restart it, it works fine.  First I thought it was a spark issue, then a fuel issue, but I feel like it's a short in the wiring some place.
    • By lmarkie
      I swapped out the Subaru motor for a Predator 670cc. If I remove the heat shield around the muffler, The stock muffler sits in there just fine with 1" to spare.
      Only problem is the exhaust exit is toward the back seat instead of out the back.
      Do you all think that the stock exhaust would be okay (just as effective) if cut a hole and welded a pipe on the reversed (opposite) end? Of course, plug the old exit end. Other option I thought of was to roll a tube 180° with a 7" center line radius and finish extention of 12" or so.
      Any thoughts?
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
