2019 Coleman 550 Outfitter, need help accessing tail gate latch screws
Go to solution Solved by Ridge Runner,
  • Solution
Success!(almost).  I followed Pop Bobs instruction.  Worked great.   I struggled trying to clear the side panel around the dump lever handle.  The side panel was hung up there, I didn’t want to break anything, so I didn’t struggle too long.  I had enough clearance to tighten up the remaining screw and added a replacement.  The replacement is a hex head, silver.   Sadly I ordered the wrong length screw, it works, but I’ll order a longer one, and take the panel off and change.  Thanks so much for your help.  IMG_1983.thumb.jpeg.50a0659423b7e862052b3cff2c2d0b7c.jpegIMG_1985.thumb.jpeg.6ebababe131193e178906e038ea2ce2c.jpegIMG_1982.thumb.jpeg.4e6c51e5624348df615733b2f77d471d.jpeg
Hindsight is 20/20.  I should have taken the remaining screw off, and measured the length.  I bought M6x16 mm, too short.  Probably 20 mm, is what it needs.
thanks again for your help.
Yes, there was some interference with the dump release lever. Bot there is enough flexibility to just deform the panel a little and it comes right out. From your picture I’d say 3 or 4 mm longer will work and not introduce any clearance issues with the tailgate. Nice job. I should have checked the tightness on my bolts while I had it apart. As an aside, I had to rethread 2 more of the screws because they were run in cross threaded with an impact driver. 😖
Pop Bob
    • By Cory J
    • By JSwearer
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Howard Elmore
