2022 Coleman outfitter 500 had a loud snap then a metallic grinding noise
Go to solution Solved by Browner010,
  • Browner010 changed the title to 2022 Coleman outfitter 500 had a loud snap then a metallic grinding noise
Wouldn't Matter if you were 1st owner, warranty is worth nothing with them. Feel your pain..went thru it myself..bought mine new from Tractor Suprise..broke with 1 mile on it.  They refused to warranty or take it back.
Check both diffs. It’s an easy start to begin ruling things out. Do you hear it in neutral? Did you have anything locked in? Does your machine have an open rear diff? When you said you can only move slowly was it that you were rpm limited or that something was slipping?
  • Solution
Found a couple issues with it and it's being tore down next month after deer season. The grinding was the ribs from the top side of the belt being ground up by the clutches (fixed) and the overheating came back and found that the OEM gaskets are so cheaply made that it's common for them to fail after 100 to 200 miles. I say gaskets because there are actually 2 in the set, one for the head and one for the cylinder and from what I gathered from the videos and forums, they both are a problem and it's wise to change them both at the same time. I was told by the one local shop that I'm lucky to have made it 750mi. without an overheating issue.
    • By hisun junk
    • By Howard Elmore
    • By JSwearer
    • By Justine
