Silverbullet
We have solved the tie rod problem. We use a heim joint chromoly and spacer.It comes with a seal and a plated bolt.This will last for years.Do not put a zerk fitting in heim.That only increases dirt getting in
Thanks Rich
  • 2 years later...
  • 3 months later...
    • By ToughLuck
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By gwares
      Price : 2500 EUR
      Everything works and new!
      WhatsApp: +33 758 56 21 59
    • By SayHiToRambo
      08 trooper 1100
      thanks!
