mule cv boot
By Marie
By rsar
By CYJSP2009
Dear Friends,
2022 Brand new Joyner CV Axles and CV Joint rebuild kits are comming
1. S650.03.02.02.00 ---Joyner 650 Commando Rear
7. 14274 --- 650 ider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
8. 15803 --- 650 Sand Spider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
Price: CV Axle: USD250/ Piece; CV Joint kit (without grease): USD110 send to door.
Buy 1 piece: Get 5% discount,
Please kindly note Qty for each part is not big and it is hard to forcast when there will be next offer for these kind of products unless there is sufficient confirmed order qty for productioin arrangement.
Payment method: Payoneer payment link ( can pay through bank account or credit card) or Paypal ( [email protected]) . Payment commission paid by the buyer.
Interested parties, please contact [email protected].
Good Luck
Casey / Leaf Asia
July-07-2022
By TjB
My dad has recently acquired a 2510 Kawasaki mule Diesel powered. It worked fine few weeks and then quit driving. Put a new belt on just to see. Still not driving. It already had a new clutch. Belt turns when in drive or reverse and back wheels are off ground to test. But wheels not turning. Thoughts?
