Silverbullet
This is the most advanced Supercharger for Chery Engines.This is a modulator system for all Chery Engines.
We are going to dyno it in a few weeks.This is the third one we have made changers to.They all worked well but want to build the best performing one.Each one has inproved torque on the low end.Different runners and shape of the manifolds.Coming soon no turbo lag.Just touch the pedal and you are gone.Inter cooler is built in.
Any questions just send your question to my email.928 344 2117 [email protected]
This system will fit Joyner,Renli,Sand Reeper and any other Chery based power train.
Thanks Rich
Silverbullet
I have seen turbo charger kits on the websites.I see pipes hoses exhaust system.But never have seen a dyno sheet.I mean never over all the years we have built performance parts.I tried to build one and it was just two twitchy.Turbo lag is just the most aggravating thing that i decided never to build one to sell.Our supercharger has none of these problems.The all you get is instant power from start to finish.We have them for all Joyner's,Models including Renli,Sand Reeper and any other buggy that uses the Chery engines.
  • 2 months later...
Believe it's actually a fuel problem I can get to run great at full throttle just rich at accel,I am using o2 wide band to monitor ratios.
Should have bought turbo kit from a reputable dealer think is my problem
Sent from my SM-G920W8 using Tapatalk
Silverbullet
Did you have a problem from the beginning or is it something that just happen.Let me know did you install the kit or was it installed buy some one else what is the fuel pressure your running an did you put bigger injectors.
Rich
I bought xy groundpounder new and same with klung turbokit
Came with an emanage blue ecu that never worked and of course no warranty.
Ended up getting Dobeck to make me a EJK module  with custom tune,using a diode to bleed off extra voltage on map sensor so won't see boost and bypassing factory o2 sensor with a simulator . Kept factory injectors
It does haul ass now  but runs rich when first start to accel for a second or 2 ,
Verified with my wide band
48 minutes ago, dwaynebradley377 said:
Silverbullet do you happen to know which wire controls rpm limiter on ecu?
Silverbullet
I am sorry but i do not know.If your cut off is 5500 RPM to 6000 RPM that is about the liniment of this motor.
  • 2 months later...
silverbullet
The 3 cylinder is the first one we are doing.The system is all set up just get one tested on the dyno. We have 2 different intakes one for the 3 cylinder and one for 4 cylinder.
Thanks Rich
    • By Jacob E freeman
    • By Kingfish
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
