I bought a Bennche 500 bighorn this past summer so far so good, got 250 miles on it. Does anyone else have a Bennche? I hear good things and bad things about these... Steeev.
  • 4 weeks later...
    • By Frank in MI
      Found a NEW 2022 Bighorn 550 DX for $9K.   Any opinions on this machine????
    • By SouthernGypsy
    • By NC4wd
    • By se3388
      Steve.............
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
