Hi guys I need help. I searched every where and can't find the answer on line or in threads. I have a 2006/2007 joyner mini viper 800cc fuel injected  chery 3 cylinder. A gear is chewed up in the transmission and I can't find parts. I live in south Florida and we don't have the dunebuggy following as out west so parts and knowledge are hard to come by. It looks like the chewed up gear is part of the shaft everything else looks fine. Wheee can I locate a replacement? Is it true that the internals are the same as some John Deere's? I've read everything from ford escort transmissions to John Deere to suzuki samurai transmission will fit. I don't need maybe I need to know what will work! Thanks in advance
Please send to my email [email protected] the gear that is bad.Also move back a littel for the transmission
8 hours ago, giericd said:
It won't let me upload any more pics, it's the gear at the bottom of the shaft on the top right, the one with the larger black nut on top
I changed some of our settings, so you should not have this issue with uploading attachments in the future.
    • By weasel
    • By Sisco
    • By camojay
      1400 miles on it
      20240817_133539_1.mp4
    • By sxr951
      parts for massimo, hisun,etc in florida? where can i get parts for the massimo 700.. like bolts and console i  didnt see any bolts on amazon to go with cylinders and any thing when rebuilding a 700 engine
    • By mac66
