My 08 renegade overheated yesterday. The cooling fan wasn"t running. I was able to hot wire the fan direct, and it worked. My question is, where are the cooling fan switch and relay located? Any help will be appreciated..
Silverbullet
The relay box is under hood i think.When you find it you can check the rely buy swaping the relays.Most of them are the same.You have checked the fuse and it was all right.So times the relay box melts in the back so take it off and check in the relay box.Might be behind seats fuse and relays.It has changed from 1 side to the other.The fan is controlled by the computer.Make sure you check the plugs on the fan and make sure the pins are pushed in.It usually a wiring problem.Just make sure the fuse and relay are not burnt in the bank of the fuse and relay box.If it is not i can send you a wiring diagram.Let me know
Rich
    • By Unhappy Kioti K9 Owner
    • By Marie
    • By rdborra
