Hi From Henderson, Nevada!
By hdtran
By mac66
By Alex
By Robert Merritt
I have an older Bristers Trailwagon model TW11 with a Honda engine. I am trying to find a replacement muffler for it. It is an unusual muffler tapped in the center instead of the end with the heat shield welded on to it. Does anyone know where I can find a new one?
By sxr951
